Initial testing done
A project log for 3D-printable PCBs
A device and scripts to print PCBs using non-conductive FDM filament.
aritz-erkiagaAritz Erkiaga 02/09/2022 at 22:380 Comments
I've tested an early prototype of the equipment to fix a resistor in place on a test circuit. While I haven't managed to, the voltage readings indicated that copper did indeed grow inside the channel, just too slowly for now (I only used a 5V gradient). I also identified other issues:
Right now I'm building a better tool, that offers 230 V pulsed electroplating (yes, just some freshly-rectified AC straight out of the wall), smarter monitoring and more control over bath flow, as well as a modular design that can be simply plugged into the piece.
