Working with a Frame Mold
A project log for DesignLab Builds: Heat Press
2022 Hackaday Prize Recycling Machines Inspo
brucejdiibrucejdii 04/27/2022 at 17:490 Comments
I drilled and tapped a basic aluminum frame to make a small test mold. Two steel plates are being used as platens to avoid direct contact with the heating surface.  Wiping Silicone Oil on the surfaces of the plates was initially used, but Mold Release Spray was easier, more convenient and work better.
