Creating the Brackets for Eboxes
A project log for DesignLab Builds: Heat Press
2022 Hackaday Prize Recycling Machines Inspo
supplyframe-designlabSupplyframe DesignLab 04/28/2022 at 17:260 Comments
We wanted to mount the Eboxes to the frame in a way that would be relatively easy to mount and also remove... using hose clamps seemed to be a good option... so far so good!  The brackets did require a mill to machine the grooves for a well for the Press Frame and a little recess for the width and thickness of the hose clamp itself.
