Ebox Frame Assembly
03/17/2022 at 18:22 • 0 commentsI edited the file to include additional through holes, not just the one.
Frame Interior Wiring
03/17/2022 at 17:51 • 0 comments -
Electronics Box
03/17/2022 at 17:46 • 0 comments -
The Final Result
03/17/2022 at 17:40 • 0 comments -
Cutting, Drilling, Tapping, Crimping Intensive Project
03/03/2022 at 18:24 • 0 commentsThis project was developed to utilize basic shop tools; and is heavy in hand drilling and tapping. Make sure that your work area is setup with a decent Drill Press, Hand Drill, Table Vise, and Metal Chop Saw...
having a Machining Mill is also a huge help but doesn't have to be utilized...
Also, You'll need various (replaceable) deburring tools, drill sizes, and tapping bits on hand.
and several sizes of 10-32 bolts.
Make sure to have access to:
10-32 Tap
3/8-16 Tap
First Step - assemble the Press
03/03/2022 at 18:14 • 0 commentsWe acquired and assembled the Shop Press; then took measurements to be able to produce a 3-Dimensional CAD file.
The provided CAD file is a close approximation of the machine's intended dimensions, slight discrepancies and the inaccuracies due to the consequence of mass manufacturing were rounded to common measurements.
