[M] Load cell update
A project log for Tetrinsic [gd0041]
A continuous, motorised slider that is force sensitive, haptic, UV self-sterilising and water resistant.
kelvinakelvinA 02/22/2023 at 08:470 Comments
I've updated the load cell and I think I can still obtain a solution.
There's still enough geometry here to use to prevent rotaional movement. The entire length increases by about 3mm I think, but I needed to move the Tetrinsic offset in TimerSpy closer by 5mm anyway-- noh way it actually became ever so slightly shorter not 3mm longer!
