[EM] Created BMI160 footprint
A project log for Tetrinsic [gd0041]
A continuous, motorised slider that is force sensitive, haptic, UV self-sterilising and water resistant.
kelvinakelvinA 04/19/2023 at 19:400 Comments
This should've been effortless, not tedious. For some reason, there's no auto generator for LGA packages. There's also no such thing as the dimension tool in the world of footprint generation, and instead, the positions of the pins had to be manually calculated.
Oh, and I did try to get away with just importing the symbol into the schematic, but Fusion declined, saying I needed a footprint first.
I copied the document things from the ADC footprint to try and retain consistency.
When is an AI that takes in a schematic input and produces a footprint going to exist? Doc drawings look pretty standardised... just a suggestion. Maybe even a manually coded, OCR-type thing could work.
This is the symbol:
