[EM] 580KV Motor Pad
A project log for Tetrinsic [gd0041]
A continuous, motorised fader that is force sensitive, haptic, UV self-sterilising and water resistant.
kelvinakelvinA 06/14/2023 at 22:200 Comments
Before looking into the I2S implementation, I'm thinking that I'm getting more confident in creating electronic library components now and should actually make the BLDC motor pad instead of mentally remembering its existance.
Not sure if the pins should be marked as "in" or "pwr". I'm going with "pwr" for now.
It's plainer than the one I've designed in EasyEDA, but it doesn't matter. I can come back to this at a later time if needed. I've gone for 0.6 * 2mm pads. The spacing of the FFC is 1mm.
And there we have it. I've also added values to the 3 sense resistors. Also, I'm not sure why the order was "U, W, V" in the EasyEDA schematic and not "U, V, W". I'll also have to check if 10K resistors are fine or if I should lower them to 4.7K.
