[T] Eliminate interconnects?
A project log for Tetrinsic [gd0041]
A continuous, motorised slider that is force sensitive, haptic, UV self-sterilising and water resistant.
kelvinakelvinA 06/20/2023 at 12:530 Comments
I wasn't expeecting these to cost so much. Ther more I started researching into other options, the more I was wondering why I was bothering with both a cable that goes to Tetent and 2 cables that go to neighbouring Tetrinsics. It would be cheaper and neater to just have a higher-pin-count cable go out. This way, I could even put VBLDC on the FPC since it would just need to handle the current of one motor.
