[R] Linear Motor
A project log for Tetrinsic [gd0041]
A continuous, motorised fader that is force sensitive, haptic, UV self-sterilising and water resistant.
kelvinakelvinA 08/08/2023 at 10:130 Comments
At this time of writing, I'm still going to go thorugh with the soon-to-be-designed dual motor Tetrinsic, but I'm still not happy about the length and height of the current solution. While the active length of 63mm makes sense as all 4 fingers can ergonomically exist in the resulting quad-Tetrinsic area, it only accounts for 54% of the total length. The thickness of 28-29mm is also limiting, and ideally Tetrinsic would be half this.
Other than width, the main ergonomic issue I need to engineer for is to obtain reliable fingertip grip whilst having a very low friction sliding surface, even when pressure in excess of 100gf per finger is applied.
To have a chance of meeting an under 15mm thickness target, a potential solition is to give up infinite-scroll and off-the-shelf hardware for a custom linear motor:
Unfortunately, I think the bigger issue is developing the software for Tetrinsic and mounting strategies, so right now I need a development solution and not an ideal solution.
