The Fusion 360 Grind
A project log for Tetent [gd0090]
An input device for quickly entering text and equations, gaming, drawing and cursor/6DoF movement.
kelvinakelvinA 04/14/2022 at 11:110 Comments
Slowly building up the confidence to, realistically, start redesigning the concept from the ground up again. It's moments like these when I seriously consider if I should put even more time into Fusion 360 models or if I should try and jump ship.
