[M] Dual Screens? Dual Speakers.
A project log for Tetent [gd0090]
An input device for quickly entering text and equations, gaming, drawing and cursor/6DoF movement.
kelvinakelvinA 07/10/2023 at 02:170 Comments
So I was wondering if I should actually enforce a maximum Tetrinsic width of 18mm so that the minimum spacing could be 19.2mm. The 1.14" LCD can be doubled up to obtain a 62mm active length Tetrinsic, though the screen itself has a lower color gamut and brightness than the 1.47" (65K 400nits vs 262K 600nits). The above Tetent is 248mm long.
I tried to hold a 29cm long box similar to how Tetent will be held and I felt that it was probably best if I kept #Leti, the Tetent UMPC, at around 30cm. Considering that the current motherboard options take up 80 - 90mm, there's only a few mm available with the current 93mm length, 52mm active length Tetrinsics. Thus, I've reverted back to the 1.47" Tetrinsic.
To stay in the 230mm of availabe space in #Teti [gd0022] without having to make the entire enclosure longer, the 80mm samsung speaker wasn't going to fit. Instead, I'll be implementing a stereo soundsystem with these:
