MicroPython with Computer Vision on RTL8722DM_MINI (AMB23)
Computer Vision has been around for quite a while but running computer vision application is always a little too demanding for microcontroller (MCU), as it requires a lot of computation and also burns a lot of power, thus it's better to offload the CV related computation to a more capable machine, for example our PC or a cloud server and let the MCU to control sensers/actuators in real time.
This little project has 2 main building blocks,
Let's go through them one by one.
1.  Video capture and Computer Vision Algorithm
To achieve hand gesture recognition, I chose to the well-known [OpenCV](https://opencv.org/) and [MediaPipe](https://mediapipe.dev/) libraries as they are open source project available on Github and they all have Python binding -- meaning I can key in all my logic using Python for quick prototyping. here is the flow chart for the logic,
Untitled Diagram
The Python script,
import cv2
import time
import numpy as np
import math
import socket
import mediapipe as mp
########## Module #############
class handDetector():
    def __init__(self, mode=False, maxHands=2, detectionCon=0.5, trackCon=0.5):
        self.mode = mode
        self.maxHands = maxHands
        self.detectionCon = detectionCon
        self.trackCon = trackCon
        self.mpHands = mp.solutions.hands
        self.hands = self.mpHands.Hands(self.mode, self.maxHands,
                                        self.detectionCon, self.trackCon)
        self.mpDraw = mp.solutions.drawing_utils
    def findHands(self, img, draw=True):
        imgRGB = cv2.cvtColor(img, cv2.COLOR_BGR2RGB)
        self.results = self.hands.process(imgRGB)
        # print(results.multi_hand_landmarks)
        if self.results.multi_hand_landmarks:
            for handLms in self.results.multi_hand_landmarks:
                if draw:
                    self.mpDraw.draw_landmarks(img, handLms,
                                               self.mpHands.HAND_CONNECTIONS)
        return img
    def findPosition(self, img, handNo=0, draw=True):
        lmList = []
            myHand = self.results.multi_hand_landmarks[handNo]
            for id, lm in enumerate(myHand.landmark):
                # print(id, lm)
                h, w, c = img.shape
                cx, cy = int(lm.x * w), int(lm.y * h)
                # print(id, cx, cy)
                lmList.append( [id, cx, cy])
                if draw:
                    cv2.circle(img, (cx, cy), 15, (255, 0, 255), cv2.FILLED)
        return lmList
############## Variables ##################
wCam, hCam = 640, 480
pTime = 0
minBri = 0
maxBri = 1
briArd =0
############## Declararion ##################
cap = cv2.VideoCapture(0) # default camera is 0, if you have another cam, you can set to 1
cap.set(3, wCam)
cap.set(4, hCam)
detector = handDetector(detectionCon=0.7)
########## Step 1 ###########
# Start a TCP server and bind to port 12345
# Use ipconfig to check the IP address of your PC
s = socket.socket()
print ("Socket successfully created")
port = 12345
s.bind(('', port))
print("socket binded to %s" % (port))
s.listen(5)
print ("socket is listening")
c, addr = s.accept()
print('Got connection from', addr)
######### Step 2 ###############
# Image capture and processing using mediapipe and opencv
while True:
    success, img = cap.read()
    img = detector.findHands(img)
    lmList = detector.findPosition(img, draw=False)
    if len(lmList) != 0:
        x1, y1 = lmList[4][1], lmList[4][2]
        x2, y2 = lmList[8][1], lmList[8][2]
        cx, cy = (x1 + x2) // 2, (y1 + y2) // 2
        cv2.circle(img, (x1, y1), 15, (255, 0, 255), cv2.FILLED)
        cv2.circle(img, (x2, y2), 15, (255, 0, 255), cv2.FILLED)
        cv2.line(img, (x1, y1), (x2, y2), (255, 0, 255), 3)
        length = math.hypot(x2 - x1, y2 - y1)
        #print(length)
        # Hand range 50 - 300
        brightness = np.interp(length, [50, 300], [minBri, maxBri])
        briArd = np.around(brightness,2)
        #print(briArd, brightness, length)
        if length < 50:
            cv2.circle(img, (cx, cy), 15, (0, 255, 0), cv2.FILLED)
    # Print FPS
    cTime = time.time()
    fps = 1 / (cTime - pTime)
    pTime = cTime
    cv2.putText(img, f'FPS: {int(fps)}', (40, 50), cv2.FONT_HERSHEY_COMPLEX,
                1, (255, 0, 0), 3)
    # Display image
    cv2.imshow("Img", img)
    cv2.waitKey(1)
    # Sending the distance between our thumb and index wirelessly to IoT device
    c.sendall(str(briArd).encode())
    print("send data success")
    print(briArd, str(briArd))
    #c.close()
2.  Running MicroPython for wireless data transmission and LED control
MicroPython is a lean implementation of Python 3 interpretor designed for microcontrollers and RTL8722DM_MINI supports MicroPython.
With MicroPython, you can control all the peripherals on the microcontroller, in the case of RTL8722DM_MINI, we can use only 13 lines of Python code to,
1. Connect to Wi-Fi
2. Start a TCP client socket
3. Control LED brightness via PWM
Here is the MicroPython code,
import socket
from wireless import WLAN
from machine import PWM
wifi = WLAN(mode = WLAN.STA)
wifi.connect(ssid = "yourNetwork", pswd = "password") # change the ssid and pswd to yours
c = socket.SOCK()
# make sure to check the server IP address and update in the next line of code
c.connect("192.168.0.106", 12345)
p = PWM(pin = "PA_23")
while True:
	data = c.recv(512)
	f_brightness= float(data[:3])
	print(f_brightness)
	p.write(f_brightness)
3. Conclusion
With Wi-Fi and other wireless communications, IoT-enabled device like RTL8722DM_MINI can really be an integral part of an **AIoT** project.  With Python language, product prototyping can be even faster and smoother.
