Smaller Tracer designed and manufactured
A project log for Tracer | A Wearable for Things!
The Tracer is an open-source ESP32-based Inertial Measurement Unit tracker
yjYJ 04/18/2022 at 21:170 Comments
Hi all,
Just a small update with hopefully bigger ones imminent. I have received my new Tracer boards that are now smaller and have a better-suited LDO with a very low forward drop to increase the usable range of battery voltages from the coin cell battery.
I am currently planning the following activities;
  1. Testing it out for tennis stroke counting - Done
  2. Tracking bicycle cadence - Done
  3. Using it to synchronize blade strokes at my local rowing club
  4. Power measurements and optimization - Done
  5. Syncing with camera footage to add data points and improve the usability
  6. Create a Tracer "hub" to synchronize several modules. Still thinking about the best way to do this as BLE might be a little limiting. Feel free to suggest :)
  7. Setting up a Crowdsupply campaign to get the hardware out to you! - On Tindie for now
Thank you all for liking and following this project it means a lot to me and it helps me keep going!
Best,
YJ
