User guide
Configuration
You can change the keystrokes that Push Push AIR sends as well the name of your Push Push AIR and the password used to configure it
You can do it by using a simple web interface, once connected to Push Push AIR via WiFi from your smartphone or computer.
Here are the step by step guide:
Please note that after 5 minutes from the last click on the buttons in the configuration page, the Push Push AIR WiFi access point will turn off automatically
How to reset the password to the factory one
If you change the password for connect to Push Push AIR and you forget it, you can revert to the factory one that is  12345678
How to reset:
