11Step 9: Problem With Initial Design
- My design includes the computer power cable and connector, the problem with this back connector design is that the power supply does not goes flat with the wall occupying some space.
- My Solution is to print the MainBodyModified.stl and connect the cable directly by removing the connectors.
