Arduino Laser Projector
Bluetooth controlled laser projector made with Arduino and stepper motors.
- XY - 2 dimensional laser scanning
- 2x 35mm 0.9° stepper motors - 400 steps/rev - 5V
- Automatic mirror calibration
- Remote serial control (via bluetooth)
- Auto mode
- Remote control app with GUI
- Open Source
LaserControl.exe
be sure to have .NET framework 4.5.2 installed
x-msdownload - 824.50 kB - 11/22/2016 at 17:36
Download
ino - 21.12 kB - 11/22/2016 at 17:36
Download
LaserControl-old.exe
for people having problem running the new version
x-msdownload - 824.00 kB - 11/30/2016 at 05:00
Download
  • 2 × 35mm stepper motors 0.9° - 400 steps/rev - 5V
  • 1 × Arduino UNO
  • 1 × Adafruit Motor Shield V2 for controlling the stepper motors
  • 1 × HC-05 Bluetooth module for remote serial control
  • 1 × Laser module
View all 10 components
Paul Barrett wrote 06/16/2017 at 01:34 point
So do we get the source code to LaserControl, or just have to trust and not be able to modify this .exe?  Or have I glossed over something?
Stanley Ondrus wrote 08/01/2017 at 21:15 point
I haven't published the source code of the app because the programming decisions are strongly related to the Arduino code. By modifying the app, you won't be able to achieve new patterns, nor new functionality, without also editing the Arduino code. However if people are interested, I have no problem with sharing the code.
kukainc wrote 01/19/2017 at 14:13 point
Arduino: 1.6.8 (Windows 10), Board: "Arduino/Genuino Uno"
WARNING: Spurious .github folder in 'Adafruit Motor Shield V2 Library' library
C:\Users\2-12\Desktop\laser\ArduinoLaserScanner-master\ArduinoLaserScanner\ArduinoLaserScanner.ino:16:26: fatal error: MultiStepper.h: No such file or directory
 #include
compilation terminated.
exit status 1
Error compiling for board Arduino/Genuino Uno.
Invalid library found in C:\Program Files (x86)\Arduino\libraries\doc: C:\Program Files (x86)\Arduino\libraries\doc
Invalid library found in C:\Program Files (x86)\Arduino\libraries\examples: C:\Program Files (x86)\Arduino\libraries\examples
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
Stanley Ondrus wrote 01/22/2017 at 16:27 point
The problem is pretty self-explanatory. You are  missing the AccelStepper/MultiStepper.h library.
By the way, when you download a library, make sure to put in the the right folder structure, Documents\Arduino\libraries\xxx, where xxx will be the name of the library, and it will directly contain all the necessary files. It is always better to use the libraries folder located in Documents, in case of you will reinstall or update your Arduino IDE. You can always delete the .github folder to remove the warnings.
Richard Balogh wrote 11/29/2016 at 22:58 point
Unfortunately, the program LaserControl.exe is not working. Simply crashes immediately after the start.
Stanley Ondrus wrote 11/30/2016 at 05:04 point
Try to manually right-click the program, go to properties, and unblock the file. Also make sure to have .NET framework 4.5.2 installed.
If it still doesn't work, try using the LaserControl-old.exe that I have just uploaded.
Hope it will help.
