I knew the v0.1 was small. I'm starting to try and consolidate my experiments down into a single board, and finalize the aesthetic parts and ... woof.
![](https://cdn.hackaday.io/images/1294161650565236628.png)
These are the mounting holes for the front of the v0.1 shroud. The fancy Voron logo is 20mm from side to side. That's what I consider to be the minimum to still be readable. And it takes up almost the entire space I would have if this is where I mounted the board.
Time to figure out a different location to mount. That's difficult since I ideally want it to be usable by someone who did PIF and cannot modify the printed parts before using the board.
