Sun Chaser 2 camera segmentation test.
A project log for Sun Chaser 2
3D Printable open source Mobile robotic solar panel to follow the sun and harvest solar energy in less than ideal locations.
dennisDennis 04/30/2022 at 14:560 Comments
Image segmentation is clustering parts of an image together that belong together.  It is a game changer on projects like Sun Chaser. The below image is a test of Sun Chaser's segmentation. Below are two images from Sun Chaser 2’s camera. The green areas are areas where Sun Chaser thinks it can travel. The dark green areas are the shaded areas that Sun Chaser can travel. The light green areas are the high sunlight target areas.
