Just been doing a few changes here and there, such as changing the model for a 7.6" screen with 495mm X and 163mm Y. I've also modelled in some cartridge placeholders. I'm thinking that moving the lamination cylinder closer and further away from the cartridge is better than my previous idea of moving the cartridge to the cylinder.With the cartridges, I'm assuming 50% of the volume to be resin, with a target of over 1L.To allow for the 495mm X axis over the original 445mm, I've done some cutting and trimming. I also intend for doors to the resin cartridges on the filleted chamfer walls, as highlighted below:
