[P] Scanner cable works
A project log for SecSavr Suspense [gd0105]
The best of resin with the best of filament; is such a 3D printer possible?
kelvinakelvinA 02/20/2023 at 12:390 Comments
There's no clip on the sensor connector and you're just supposed to squish the cable in. The contacts are on the top of the connector whereas it's on the bottom on the breakout board. I got the cable where contacts on both ends are on the same side, conviniently meaning that the pinout markings on the breakout board match the pinout numbering from the previous log.
