Still Tinkering with Calibration
A project log for Bendulum Clock
A new kind of electromechanical clock
Dave EhnebuskeDave Ehnebuske 10/14/2016 at 18:020 Comments
I reworked the temperature-compensation calibration once again to further reduce its sensitivity to the history of the temperature changes the clock encounters as it calibrates itself. Also, I changed the calibration model to be a simple linear least-squares fit across the whole temperature range.
Still testing to see if the small, sudden changes in speed noted with the last update exist. Jury's still out on that. If so, it's got to be something physical. Probably something moves with a thermally induced stick-slip motion.
