Overview
Hey, thanks for checking out my project! As I said in the description, this project aims to develop a low cost method of recycling electric scooter motors into a small scale home energy generation system. This section will provide a brief outline of where the project is at, and where it is headed. Project logs provide technical details on individual elements.
Before I get into the project details - I just want to elaborate on the thanks in the description. Thank you so much to the people that helped me get this project to where it is. Thanks to Daniel (One of the best - if not the best - lecturers) for not only giving me the push I needed to get it made, but also for talking through a lot of the technical details, especially when I was deep down the fluid dynamics rabbit hole. Thanks to my dad for being there with some really solid practical help and advice - I think that the tower would have fallen over the first time I tried a live test if it hadn't been for some of the rock solid mounting methods you came up with. Another big thanks to the engineering techs at my university, for some more solid advice.
As it stands, the project breaks down into three major elements:
- Development of blades and rotor suitable for harvesting local wind
- Development of generator capable of maximising energy output for local wind conditions
- Development of an electronic control system for braking, and for handling energy output into a battery bank or local load
Currenty I have put a lot of time into the first bullet point, and developed a methodology for creating a rotor suitable for specific wind conditions. This process has also highlighted the fact that the scooter motor may not be suitable for operation by a wind generator, as in order to ensure a low cut-in speed the operational RPM of the motor must be reduced to a point where output power is minimal.
Blade Development
In the final trimester of my engineering degree I worked on this project as a self directed study course, giving me a lot of time and resources to develop elements of the system. During this trimester I worked on developing a methodology for analysing local wind conditions, and developing a rotor to those conditions.
This process involved a lot of iterative design, and avoided in depth fluid dynamics (as I was studying electronic engineering, mechanical was a bit beyond the scope of my course). In order to do this, I used a software package called QBlade to handle fluid simulation. This was paired with research into airfoils developed for small wind turbine applications, and resulted in blade profiles targeting specific tip speed ratios (TSR).
Further detail is provided in my blade development project log (and in the report I wrote for this section, found here), but if you just want to see the rotor operating at maximum speed (With no generator gearing attached), check out this video:
Generator Development
Part of the self directed study work looked into details of the scooter motor as a generator. The brief amount of research into this topic is detailed in a log, however in summary the research found that wind generators (and generators in general) tend to have what is effectively a maximum power point on their power vs RPM curve.
Additionally, it was found that the scooter motor needs to run at a reasonably high RPM to begin approaching this point. Further analysis of the motor power rpm curve could provide insights on exactly where on this curve the scooter motor should be operated for maximum efficiency.
However, this produced another issue. The turbine can drive the generator at it's maximum speed, however it cannot self-start. In order for the turbine to self start, a low gear ratio needs to be introduced. This lowers the starting torque of the generator, reaching cut in speeds as low as 2.1m/s.
So a low cut in speed was achieved, but another issue reared its head. With a low gear ratio, the resulting RPM of the generator is reduced. This means that the generator may be able to self start, but the resulting power output is incredibly low.
As I say, further detail in a log (and in the reports I have written for my self directed study). If you are just interested in seeing the generator integrated with the rotor, check out this pic!
Into the Future
So I have a very effective rotor, and a method of developing new rotors optimised for local wind conditions. What I don't have is a generator that can utilise this rotor to generate useful amounts of energy. Future work on this project will need to address this generator problem.
There are a couple of things I want to try. First up, I want to make a jig to generate a power vs RPM curve of the scooter motors I have used. This information would allow me to target a specific RPM for the generator, and draw conclusions on whether I can develop blades capable of operating the generator at this speed while still providing a low cut in speed. Analysis in the final testing report of my self directed study seems to indicate that higher torque from the rotor may make this achievable. Torque output of the rotor could be increased by introducing more blades with larger root sections. This could mean going to 5 or 6 blades.
If this is not a feasible way to get the motor to an optimal operational speed, I am interested in researching winding my own generator. Currently, I am thinking it may be possible to strip the copper and permanent magnets from the scooter motor, and reconfigure them into a generator with a lower starting torque. Other elements of the motor could still be recycled into the turbine, by using things like the bearings to hold the drive shaft stable.
Once power is successfully generated in usable amounts, a system will need to be developed for utilising this energy. I am keen to develop some equivalent of an MPPT controller for manipulating the apparent load to ensure the generator operates at the desired RPM. This will require a lot more research, and honestly is a few years down the line.
If you're still here, thanks for checking out my project! I look forward to sharing future developments, leave a comment if you are keen to know anything about my janky process!
Sam Griffen
