sharpening the roller bearings
A project log for PullStruder: from plastic bottle to PET filament
Ever wanted to use plastic bottle for 3d printing ? Here is how to !
jp-gleyzesJP Gleyzes 09/19/2022 at 10:110 Comments
Sharpening the bearings is needed to get a nice 90° sharp edge on each roller bearing.
Mount the two bearings on a 8 mm rod, then grind the circumference on a belt sander.
Unlike what I am doing, YOU SHOULD WEAR GLOVES...
Then flatten the edge of each bearing.
That's it, your bearings are ready to be mounted on the ribbon cutter.
