Revision 4.0 Status Report
A project log for All-In-One Gamma-Ray Spectrometer
More sensitive to gamma radiation than a Geiger counter with the added bonus of telling exactly what's inside your samples!
nuclearphoenixNuclearPhoenix 11/28/2023 at 22:550 Comments
The latest hardware revision of the board is now almost complete. I've finished work on the hardware, did some testing and adapted the Arduino sketch to work on the new hardware just now. I'm very shortly going to talk about all the changes with the Rev 4 hardware.
Most of the actual circuitry has been taken straight from the last revision with only minimal changes. So like I said in one of the last logs here on Hackaday, this is mostly a quality of life update and largely concerning the change of the PCB layout.
Here is a list of all significant changes to the electronics:
Admittedly, this is all a bit technical, but I guess you're here for the tinkering and the behind-the-scenes stuff anyways ;D
In short, what does this mean for you, the user? Well, first of all, you finally got a buzzer and an additional button, how nice is that? You also got a more reliable option to connect the SiPM if you so desire. The device should also be a bit more stable now in general. And on top of all of that, I got a noticeable improvement in energy resolution (up to 1%, but I have to do some more testing on that) and I was even able to get a usable spectrum down to about 10 keV due to the less noise!
Here are two test spectra that I did that back what I just told you (only 30 minutes, so expect results to be a bit better with longer recordings):
About 9% energy resolution with a 9% scintillator and a single SiPM.
Easily able to fully resolve the lower ~26keV peak of Am-241. Range goes down to about 10keV.
Here are some renderings on how the final PCB looks like (with an OSHWA mark placeholder). I already have an assembled one here, but that's nothing worthy of showing off due to all the soldering and changes I did to it ;)
I am going to do some more testing for the Arduino sketch that runs on the Pico and I still have to implement the button and some other buzzer-related things. It already works totally fine and stable just like the old software, only some functions are missing and I want to do some more optimizations on top of that.
There will also be another batch of assembled PCBs on Tindie in a couple of weeks, this time the pin female headers on the board will also come pre-assembled in contrast to the last batch where they were left out. Price will probably need to go up like $5 per piece to compensate for the added parts and the 4L board, but I think that's more than fair given the number of improvements ;)
So stay tuned for more updates on the Tindie stock as well!
In addition to all of that, the PCB will also get a final, tiny update when I get the OSHWA certification again (just adding the mark to the silkscreen). There is still a lot to do for me, I'm going to slowly update everything here on Hackaday and on GitHub over the next few weeks, I will keep you updated.
Have a nice week!
