Hackaday.io Hackaday.io
Recently Updated Most Likes Newest Project Lists
Courses Tutorials Events Hackerspaces Profiles Hackaday.com Tindie Marketplace
Sign up Log in
stm32 HiFi usb sound card DIY
Black /Green pill stm32f401 , high quality, low noise DAC based on 2 PWM timer channels with virtual software Sigma Delta ADC
Samsonov DimaSamsonov Dima
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2k views
0 comments
23 followers
  • Description
  • Details
  • Files 0
  • Components 8
    • View all
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
2k
0
23
19
Team (1)
  • Samsonov DimaSamsonov Dima
Join this project's team
  • stm32f4audio
hardware
ongoing project
Software
STM32 audio usb RETRO
This project is submitted for
  • Hackaday.com Tip Line
This project was created on 05/02/2022 and last updated a month ago.
Description
DIY about $3-$9 (depends number of displays) low cost solution Software low noise DAC based on 2 PWM timer channels with virtual soft Sigma Delta ADC between stream from usb and PWM output. There is implemented "sigma-delta floating point encoder" workaround of native stm32f401 limit 10.5 bits on 44100 Hz (1904 levels=84MHz/44.1KHz ) So, we can have for only $3 ,very low noise , high sound quality solution, which better then most onboard sound cards !
There is implemented virtual software second order sigma delta adc for the shift quantization noise to high frequency. see here (it provide useful links at the end):
https://www.analog.com/media/en/training-seminars/tutorials/MT-022.pdf
But instead one bit ( two levels ) i use more bits (0-MAX_LEVELS) Same technology can be used for esp32 high quality sound rendering.
stm32f401cdu6 version https://github.com/sdima1357/stm32f401cdu6_Audio
stm32f401ccu6 version https://github.com/sdima1357/stm32f401ccAudioNative
Details
Components
  • 1 × stm32f401cdu6 or stm32f410ccu6 green pill board
  • 2 × st7789 240x240 ips display (0,1 or 2optionaly)
  • 1 × connector audio 3.5mm
  • 2 × resistor 100 Ohm
  • 2 × resistor 220 Ohm
View all 8 components
Log In/Sign up to comment
Sign up with Github
OR
LP-2010 AES17 1998 Switching Amplifier Low Pass(low-pass) Filter
Project Owner Contributor
yakeyake
The 2015 Hackaday Prize
Acquire EEG, ECG, EMG (medical instrument) signals while rejecting AC coupled noise
Biopotential Signal Library
Paul StoffregenPaul Stoffregen
OpenDAC HD
Mike LuMike Lu
The 2017 Hackaday Prize
The world's smallest and simplest theremin
Minimin Mk1
eagleisinsighteagleisinsight
Going up?
© 2022 Hackaday
Yes, delete it Cancel
You are about to report the project "stm32 HiFi usb sound card DIY", please tell us the reason.
Send message
Remove Member
