Assembled the PCB
A project log for DIY Solar Bottle Lamp
Solar Bottle Lamp is a solar-powered light that is constructed from waste plastic bottles. The design idea is to reuse waste plastic bottles
open-green-energyOpen Green Energy 10/24/2022 at 01:370 Comments
Arranged the SMD components as per the schematic diagram, so that it will be easier for placing the components on the PCB.
First I have applied the solder paste by using a solder paste syringe.
Placed the components by using tweezers
Cooked the PCB using my Hot Plate.
Soldered the Through Hole Components : 3 x JST connectors, Push Button Switch, and USB-C Socket
