• 1
    E-Paper Introduction
    The 2.9” active area contains 296 x 128 pixels and has 1-bit white/black full display capabilities. An integrated circuit contains a gate buffer, source buffer, interface, timing control logic, oscillator, etc… are supplied with each panel.
    You may refer to the official 2.9-inch e-Paper HAT(D) datasheet to know more information about this module.
  • 2
    Connection wiring diagram
    RTL8722DM / RTL8722CSM wiring diagram:
    1
    1
    RTL8722DM MINI wiring diagram:
    1
    1
    RTL8720DN(BW16) Wiring Diagram:
    1
  • 3
    Build and upload the example
    Download the Eink zip library, AmebaEink.zip, at https://github.com/ambiot/ambd_arduino/tree/master/Arduino_zip_libraries
    Then install the AmebaEink.zip. Open the “DisplayQR” example in “File” → “Examples” → “AmebaEink” → “DisplayQR”:
    1
    Modify the URL in the loop() section as you wish, after that, verify and upload the code to the Ameba board. After uploading the sample code, press the reset button, a QR code generated based on the URL of your input will be shown on the E-paper module. The QR code showing below leads to our
    Ameba IoT official website.
    1
