If you noticed it is only 20 or 21 (for the people on the other side of the World) days left until Christmas :-)
So its time to get or prepare the gifts ;-)
For my mother i will prepare a glowie orchid. The plan is to submerge the sealed AtmegaHearth in the flower pot and illuminate a glass "thing" (i even don't know the german word) which stays next to the orchid.
On the Pro side:
- my mother likes plants
- my mother likes orchids
- my mother likes those glass things
On the Con side:
- It needs Power
- Its a bit complicated to add the pcb to the flower pot
First i "casted" the PCB in Hotglue. Only the LED got a Window made by a part of a MonCherie box.
I tested it in water... it worked:
After this nice success i also tried a bit of toner transfer - worked also okay but the standard paper was a bit difficult to remove... should try some other paper types. It was pretty easy. Just print the "artwork" mirrored on a paper and put it on the hotglue as long as it is still hot.
In person it looks a lot better. It's a bit kitschy but its not visible by default :) Here is another close up.
I hope you enjoyed this post also.
Stefan-Xp
