RPSD Extruder
A project log for RPSD: Recycled Plastic Skateboard Deck
Tackling plastic waste, democratizing access to skateboarding and proving to people what products made from waste can really do.
jason-knightJason Knight 08/24/2022 at 20:290 Comments
To make recycled plastic skateboard decks, you need an extrusion machine. It melts the plastic into a liquid and fills the mould by pushing the molten plastic out of a barrel using a motorized screw.
There are many variations of the extrusion machine out there but none were perfect for our needs, so we set out to design one that fits, as a set, with out mould, to complete the production system. What differentiates ours is that it has an adjustable height, wheels, and lean profile (700mm wide) making it practical for events, demonstrations or simply moving around the workshop. The adjustable height allows it to be used for a broader range of applications that require a low or high profile, or for interactions that involve children and shorter people.
Like all our work, this machine is fully open source and online now, you can find the download kit  📦 HERE 📦
This kit includes all the information you need to build your own extruder.
The extruder features an extrusion barrel designed by Ateliers des recycleurs fous. It is from their model “C4-PO”. More information, such as how to build it, can be found here:
atelierdesrecycleursfous.fr/extrudeuse
Special kitos (Thanks) to Caracara Collective for the many kinds of support given during this phase of the build.
Electronics Schematic
RPSD-EXT Technical Data
General
Model
RPSD-EXT
Version
1.0
Type
Extrusion
Year
2022
Dimensions (length x width x height)
1400 x 700 x 500 min 1400 max
Mass
200 kg
Total Power
5 kw
Total Amps
12 A
Heating
Power supply
Three-phase electric - 380V
Heating element type
Band Heater / Collar
Number of heating elements
6
Heating power
2 kW
Operating temperature
0 to 250 °C
Motor
KW
3.3 kw
Amps
137 Nm
RPM
187
User Process
Materials processed
Soft plastic, Hard plastic
Filling Method
Extrusion
Construction
Construction materials
Steel Frame
Material Cost (EU)
7500 Euro
Manufacturing time
± 5 Days
Workforce
1 Person
Difficulty
Connections
Electrical
Three phase plug socket 16 A
Pneumatic
Compressed air for cleaning
