Earlier project logs
A project log for Notkia (name change planned)
Linux phone in the shape of Nokia, with LoRa+WiFI+BT connectivity.
Reimu NotMoeReimu NotMoe 06/29/2022 at 19:450 Comments
Click on the links to see details. They're all our tweets.
2022-04-12: Received first batch of the X1000E SoM
2022-05-15: First prototype worked
2022-05-19: LVGL player demo worked
2022-05-22: Second prototype done designing
2022-05-27: "Bad Apple" animation on Notkia
2022-06-01: Faster "Bad Apple" with USB audio
2022-06-01: Second prototype assembled with the shell without problems
2022-06-03: Keypad is worked
2022-06-04: LCD backlight worked
2022-06-05: Demonstrated the USB OTG functionality with RetroWave OPL3
2022-06-09: The GNSS chip itself worked
2022-06-11: Running Pokemon Gold in the VisualBoyAdvance, although laggy
2022-06-12: LoRa worked
2022-06-15: WiFi worked
2022-06-16: Bluetooth worked
2022-06-18: RGB indicator LED worked
