Time to make a conclusion of this project.
Now
As of 2022-10-22, here's the summary of the V2.0 hardware:
Working:
- LCD screen
- Keypad
- WiFi
- RGB LED
- RTC
- USB OTG
- Both Device & Host mode works
- Power management
- Battery gauging
- Battery charging and OTG 5V boost
- Audio
- Only playback is tested. Both loudspeaker and earpiece work
Partially working:
- Bluetooth
- Needs a jumper wire to connect 32kHz clock source to the AP6214
- Suspend-to-RAM and wakeup
- The old X1000 SoM doesn't have a 32k crystal, so it uses a lot more power
- LoRa
- The SX126x SiP module works, but the 433MHz antenna barely works
Not working:
- GPS
- Subject to removal
Future
Name change
The earlier name poll has a 4-way tie. So Idk.
However, a staff from Hackaday showed their support of this project. So I'm not sure if the name still needs to be changed.
![](https://cdn.hackaday.io/images/9472071666371574509.png)
Opinions are welcomed.
New hardware reversions
The V3.0 hardware is still being designed. TBH I don't have a lot of time recently.
Nevertheless, all the design files will be uploaded to GitHub soon and you can hack it by yourself.
