May 25th
A project log for 9 Board
It is a board with 9 divisions made to help people who suffer from autism.
alesaitocalesaitoc 06/06/2022 at 14:570 Comments
We finished the design for the box and the walls in order to laser cut it and then assemble it together.
We had some trouble finding the proper glue to fix the outer walls but we manage to make it work. We ended up using super glue to place them correctly and let it dry.
Also we where making the finishing touches to our code of the LED ring. The final result showed 3 basic colors that turned on by clicking in the button. The three colors where red, blue and purple.
 We also made the finishing touches of some components of the inside of the board. In the gel we added some figures and other small pieces of clay to give it more texture and color. Also we defined the emotions with molding clay for it to be 3D and the user would be able to touch it.
