SmartSpeaker
A LMS enabled spekaer based on PiCore Audio Player
0 followers
A LMS enabled spekaer based on PiCore Audio Player. This Speaker can sync the sound Stream with other similar (LMS) devices over Wifi.
The advantage of picore is that the whole OS runs in RAM. This also solves the problem of the unstable microSD card (this is only needed for booting)
OS: PiCore -> https://www.picoreplayer.org/
Software: LogitechMediaServer
Server: -> on a Virtual machine
Speaker cabinet calc:
Resonanzfrequenz fs
130 Hz
Mechanischer Q-Faktor Qms
4,30
Elektrischer Q-Faktor Qes
1,74
Gesamt-Q-Faktor Qts
1,24
Äquivalentes Luftnachgiebigkeitsvolumen Vas
0,84 l
Gehäuse
Volumen pro Speaker: (nur gehäuse, elektronik noch nicht dazugerechnet)110mm x 90mm x 180mm
1.782 l
Volumen Elektronik:
0,198 l
reflexrohr:
20mm durchmesser und 50mm lang
Adobe Portable Document Format - 433.82 kB - 06/06/2022 at 11:43
Preview
Download
Standard Tesselated Geometry - 2.13 MB - 06/06/2022 at 11:43
Download
Standard Tesselated Geometry - 278.21 kB - 06/06/2022 at 11:43
Download
Standard Tesselated Geometry - 164.34 kB - 06/06/2022 at 11:43
Download
Standard Tesselated Geometry - 598.42 kB - 06/06/2022 at 11:43
Download
View all 14 files
  • 2 × Visaton FRS8 Spekaer
  • 1 × Raspberry Pi 3
  • 1 × 500g PETG or PLA
  • 1 × PSU 12V (min. 4A)
  • 1 × HifiBerry
View all 4 project logs
