Status - Working Code
A project log for SD/Serial Card Loader
Load/Save files from/to an SD card to/from a Serial Port
land-boardscomland-boards.com 06/15/2022 at 17:050 Comments
Got menus working for the serial port configuration for:
Menus are all in place, but not all of the functions are created for the above. The baud rate select menu is working/tested and set to 9600 baud as default. Tested at 9600 baud and 300 baud.
Got UART transmit code working.
This is now a minimal viable product.
Working code is here (SDLoader_V2-20220615..zip file).
