• 1
    Introduction
    This tutorial will show how to interface the M5Stack Core2 with the Bolt IoT Cloud platform and transfer the data between Bolt IoT Could.
  • 2
    Get PCBs for Your Projects Manufactured
    You must check out PCBWAY for ordering PCBs online for cheap!
    You get 10 good-quality PCBs manufactured and shipped to your doorstep for cheap. You will also get a discount on shipping on your first order. Upload your Gerber files onto PCBWAY to get them manufactured with good quality and quick turnaround time. PCBWay now could provide a complete product solution, from design to enclosure production. Check out their online Gerber viewer function. With reward points, you can get free stuff from their gift shop.
  • 3
    Project Flow
    Bolt IoT platform gives you the capability to control your devices and collect data from IoT devices safely and securely no matter where you are.
    Get actionable insights by deploying machine learning algorithms with just a few clicks to detect anomalies as well as predict sensor values.
    Bolt IoT has specific hardware which allows you to directly from your sensors to theBolt Cloud platform.
    If you have your own Controller, but you want to use the Bolt IoT Cloud, here is the solution. In my case, I have my ESP32 Controller which is from M5Stack.
    I have used UART Protocol to communicate and transfer my M5Stack data to Bolt IoT Hardware and then the Bolt hardware will send the data to Bolt Cloud.
    M5Stack Core 2 is an ESP32-based microcontroller that has an inbuilt TFT Display, Speaker, Microphone, and some additional sensors so that we can use this Core2 for a wide range of applications. We can't directly connect your own hardware to Bolt IoT, we are going to use Bolt IoT to communicate with the Bolt Cloud platform.
    M5Sack Core 2 has three IO ports.
    • GPIO Port
    • I2C Port
    • UART Port
    we are going to use UART communication between M5Stack and Bolt IoT. Bolt IoT out also has a UART Port by this Port M5Stack will communicate with Bolt Cloud.
