After gathering more than 40 grams of nesting material there seems to be a change happening inside the birdhouse. Before April 13th you can see the little bird coming into the birdhouse at night to sleep. After April 13th it looks like there is now someone permanently inside the birdhouse. I'm guessing this is probably the female nesting.
![](https://cdn.hackaday.io/images/5899031681706947179.png)
