Building the heater coils
A project log for Easy Bake Fab Lab
A study into building a semiconductor fabrication lab for the home hobbyist.
steve-hernandezSteve Hernandez 06/16/2022 at 13:120 Comments
I chose Kanthal wire as the heater core element. I used a metal rod to coil it into a tight coil. I used stainless steel bolts to secure the ends and to use as an AC electrical connection. I was targeting a length of kanthal with a resistance around 11 ohms  which provides about ~10.9 Amps of current for a total of 1.3KW of power.
