WW18 BrainfuckPC 3D Model
A project log for BrainfuckPC Relay Computer
Von-Neumann 16-bit relay computer with Brainfuck++ instruction set
artem-kashkanovArtem Kashkanov 05/04/2018 at 22:280 Comments
I started making BrainfuckPC base plate and for doing that I need full 3D model of PC.
I created all blocks with different assumptions. It's a final blocks arrangement! Final dimensions are 1000 x 650 mm.
Base plate - Aluminium 6mm.  Work is in progress, so you can check current model state on Autodesk site here: https://a360.co/2rnFQnh
