Cables. Many cables need to be crimped
A project log for BrainfuckPC Relay Computer
Von-Neumann 16-bit relay computer with Brainfuck++ instruction set
artem-kashkanovArtem Kashkanov 09/03/2018 at 08:590 Comments
Cables for blocks interconnection are partially done.
25 cables 16-bit width. Using single-line connectors was the greatest fault in device construction planning. Double-line 2x10 connections would be more useful.
