WW08 Update
A project log for BrainfuckPC Relay Computer
Von-Neumann 16-bit relay computer with Brainfuck++ instruction set
artem-kashkanovArtem Kashkanov 02/26/2017 at 19:440 Comments
I routed almost all modules:
ADD+Carry module, D-trigger module, 5AND, 2AND/2OR module, base board and working on memory module
Currently I'm working on making pcb's - I'm doing all pcb by myself using photoresist technology.
I already etched 17 of 26 panels 20x15 cm - each panel contain 9 modules and 4 relays on each module. When I finished etching I will start with solder mask.
6 pcb's - D-trigger,
2 pcb's - ADD+C
3 pcb's 2AND/2OR
5 pcb's - base panel each for 32 modules. I need one more of this type
1 pcb's 5AND - I need 4 of them for paralle carry.
I created roadmap webpage in github repository where I update all steps
https://github.com/radiolok/RelayComputer2/blob/master/roadmap.md
