WW52.2 Test suite
A project log for BrainfuckPC Relay Computer
Von-Neumann 16-bit relay computer with Brainfuck++ instruction set
artem-kashkanovArtem Kashkanov 12/26/2017 at 08:310 Comments
I'm developing an "absolute encoder" - 16 position switch with binary output. I already have two this switches, but for one word I need 4 of them, so I want to draw all parts and print them.
On the left  - key cylinder with binary rings, on the right - miniature switches.  Top ring is to hold cylinder in each position. I'll add little spring-loaded balls between them - the same mechanism I found in my real switches.
