Max uptime on a 8000 mAh battery
A project log for ShaRPIKeebo - Nano Linux Computer
A tiny Raspberry Linux computer with a keyboard, a daylight-readable screen, and a long-range transceiver
pcadicpcadic 06/26/2022 at 12:172 Comments
Study and technical test to check the maximum uptime on a 8000 mAh battery
pcadic wrote 07/01/2022 at 19:51 point
you can plug a power source on the usb c. It will charge the batt and act as a second power source. The 433mhz trx comes on a SMA antenna so yes you can plug a yaggi 12 dbi if you want :)
tywy wrote 07/01/2022 at 19:41 point
Can I use 2 independ power source?
for example lipo or 18650 battery? ideal is step-up-down from 0 to 25V power input.
Why not move a raspberry pi cpu or other directly to pcb motherboard?
