Model Polish
A project log for DSKY
Create a working DSKY using a 3D printer and my AGC simulator running on a Raspberry Pi and slave Arduino Nanos.
wglasfordwglasford 07/15/2022 at 21:160 Comments
I added a nameplate to the back, just to make the model more realistic.  There is a thin part named NamePlate that I 3D printed.  There is also a file named NamePlate to print on thick card stock.  Glue the paper name plate to the 3D name plate.  I colored the side of this assembly with silver paint and then glued this to the back of the DSKY.  To make it even more realistic, I dug up four small screws with rounded heads and cut the heads off and glued them to the four corners of the name plate.
