Got the big window fan in for the br, $40, 10" 120V fan with louvers. Unfortunately breaking my "no mains" rule already bc it didnt come pre-wired, AND needs a dimmer to run even remotely quietly. Think this is more of an industrial thing but I want the ability to move that much air when I don't care about noise too and couldn't find a good alternative. I'll have to be careful with the boxes and shit to make it pretty failsafe.
Got this https://www.tindie.com/products/bugrovs2012/ac-dimmer-module-controller-board-arduino-v20/ dimmer off tindie to do the actual control, I'll probably have an arduino to do the low-level timing and ESP for control.
Also finally got around to getting a proper ring/spade terminal crimper, to ground the thing.
Also got a free desktop and got it to boot bodhi (and connect to wifi through a dongle. That was a whole thing in and of itself...). May run the main logic on that but mosty using that for the bar lighting.
May post that as a project at some point too, we'll see.
John Duffy
