I received the custom keycaps for the Mathboard today. They were made using a UV printer by a German maker I met at Nantes Maker Campus 2022. He has been kind enough to help me out with getting my design onto the keycaps.
The result looks pretty good!
![](https://cdn.hackaday.io/images/577841664133595101.jpg)
If you have a UV printer and want to make these keycaps yourself, the .svg files are available at the Mathboard Github repository:
https://github.com/nup002/Mathboard/tree/main/hardware/keycaps/decals
Very nice! I happen to have seen these decals in the making (I'm not the kind unnamed maker, though). For those who don't have a UV printer -- alternatively you can use water slide paper (fiddly and needs additional coatings of varnish, but relatively cheap): https://hackaday.com/2021/06/12/waterslide-decals-for-wingding-keycaps/
