A sneak peek..
A project log for CoreXY Ender 3
Converting old Ender 3 to coreXY printer.
aaron-deisterAaron Deister 01/06/2024 at 08:100 Comments
Hi all,
Tanguy recently added me to this project. I've been working on remixing it significantly, as I was wanting to build an Ender 3 conversion that's capable of being fully enclosed, and ideally should have a bit sturdier of a frame. I'm including a screenshot of what I've come up with so far, and am working on the BOM right now. While I'm excited to share it with you, I should warn that this BOM will be significantly more expensive than the original project!
Edit to add - The frame braces shown below are courtesy of @NoWarrenty over at Printables. I remixed the 165mm brace to create the smaller ones: https://www.printables.com/en/model/264710-printer-frame-stiffening-braces-different-sizes
