FlyingBear also publishes the modified grbl source code!
A project log for Don't ignore Open Source licenses!
Up to now, most manufacturers of laser cutters of the mid to lower price range make use of grbl, but totally ignore the GPL v3 license!
norbert-heinzNorbert Heinz 04/13/2023 at 06:580 Comments
FlyingBear has joined the party and meanwhile publishes the source code of their LaserMan firmware. They do so with a link directly on the page with the firmware binaries and that's exactly how it should be. The firmware including source code itself is hosted on Google drive:
https://drive.google.com/drive/folders/1SOQ87Hw8J7gjQCtrIzGSMM4Fh3et-Jet
The repositories of Ortur still look a bit messy with many empty folders and links to closed source binaries :-( However, the core elements of their firmware is published. The repositories of interest are those of Firmware 1.4x:
https://github.com/Ortur-Tech/Ortur_Laser_Firmware_14X
as well as 1.7x:
https://github.com/Ortur-Tech/Ortur_Laser_Firmware_17X-18X
