90 mm/sec at base. 300 mm/sec at top. Printing is acceleration limited and likely never reaches 300 mm/sec. There interesting thing is that it is nearly impossible to out run the extruder, meaning the extruder can push out more melted filament than the printer can move to extrude it. Check videos to see it in action.
