Design files now on Github
A project log for LoRa End Node & Remote Monitoring System
A LoRa remote solar powered monitoring system designed to be as flexible as possible and connect to a variety of sensors/sensor modules
jstuartjstuart 08/02/2022 at 22:430 Comments
The design files for the LoRa Remote Monitoring system are now on GitHub.
I am in the process of working on revision 2 of the PCB board set and documentation.
