Chisel counter weight
A project log for Pi Zero 2 Robot Navigation Head
(it's a gimbal) with OpenCV/range scanning and IMU for navigating wireless robot platforms by API
jacob-david-c-cunninghamJacob David C Cunningham 11/20/2022 at 04:120 Comments
Today I made this manual web control, it's building towards the web interface that would monitor the telemetry/decision making by the autonomous part.
It was a good experience to do this because it exposed some problems like bad code and also how tiny the FOV is from the camera potentially... which means multiple images and probing before being able to make a decision where to go.
It's also nice being able to see where the Lidar beam is on the image since you see this purple pattern.
I also realized how bad of a design this thing is (top heavy) and the servos stop too abruptly causing vibration.
I did print mounts so the head can be attached to the robot securely-ish (some slop).
Without the chisel (yellow bar) in the back it is very tipsy.
